Activity › Forums › Adobe Premiere Pro › PP2 won’t load, hangs at splash screen then disappears
Posted by Frankipanki on January 13, 2007 at 8:51 amPremiere pro 2 will not load anymore. splash screen gets as far as loading compiler quicktime.pm then disappears off screen, re-installed pro twice.
Any idea chaps what is wrong?Frankipanki replied 19 years, 7 months ago 5 Members · 8 Replies -
Mike Velte
January 13, 2007 at 8:42 pmTr deleting Premiere’s Preference file;
D:\Documents and Settings\mike\Application Data\Adobe\Premiere Pro\2.0\Adobe Premiere Pro Prefs. -
Frankipanki
January 13, 2007 at 9:29 pmTried that mike still the same just occured to me that pp2 went haywire after partial install of Windows Vista beta,how can i remove this as windows now starts up with an option on the dos screen of starting windows normal that worked earlier or carry onwith the install of the beta decided to leave Vista till the official release.
Kind regards Franki -
Vince Becquiot
January 14, 2007 at 1:55 amOuch, on Vista ???
I couldn’t get PP2 to run on the OFFICIAL release on one of my machines, never mind the beta 🙂
Wipe it out and install XP if you want to get any work done.
Vince
Heelflipp900
January 26, 2007 at 7:35 amHey guys,so I’m having this exact same problem, except my OS is XP. I deleted the file as someone else suggested in this topic, however after attempting to open up Premiere Pro 2 again, the splash screen still disappeared at compilerquicktime.pm. So any help would be appreciated! Thanks!
Frankipanki
January 26, 2007 at 1:23 pmDiscovered that aslfoundation .dll was missing, after a lot of searching on the web found this file but dont know how to associate the file back to PP2.
Any help would be appreciated.
Thanks Guys
Franki -
Jon Barrie
January 31, 2007 at 3:33 amI had a problem with a repaired XP and my PPro2 wouldn’t load up… I did everything to get it running again. It would hang in the splash screen when it hit the Quicktime drivers. I then realized after hours of wasted reinstalling that I hadn’t reinstalled Quicktime yet!
If your problem is at splash when it hits the QT installers/drivers:
reinstall QT.Hope that helps. – Jon
