Activity › Forums › Adobe Premiere Pro › PP2 tv output hardly to see
  • PP2 tv output hardly to see
    Posted by Hector Melendez on February 22, 2006 at 9:47 pm
    I have found that with PP2 the tv monitor output is very jerky.
    Also the audio and video in the TL wash-out when playing back the sequence. I mean the secuence seems not to have the waving of the audio and either the keyframes of the video track. I have to stop the playback to recover all and when starting again the video seems to playback better for about 30 seconds until everything start jumpy again.
    Do this have to see with the computer??
    HP multimedia center
    Athlon 3400/ 1 gig ram- Nvidia 5200 128mb video card
    3 HDs- 1 for system /1 for capturing/ 1 for assets
    air cond. at all times
    This Pc works good with PP1.5
    What I have to change to achieve a better monitor output?
    The video is hardly to watch.
    Redgum replied 20 years, 7 months ago 2 Members · 2 Replies
  • Hector Melendez
    February 23, 2006 at 2:35 am
    I found that after I dissable the TL auto scroll now the playback is much better. Only problem now is that the Playback hesitate to start. The response to review back & forth is sluggish; not as PP1.5.
    Any sugestion is welcome.
  • Redgum
    February 23, 2006 at 8:00 am
    From our tests we have determined that Prem Pro2 needs about half a Khz more power than PP1.5 to achieve the same performance. So if you had a 2.8 Mhz CPU you now need a 3.4 Mhz CPU. This is not science simply extensive trials carried out over a few weeks on the one machine with different processors. This is not bad, simply progress. In most areas PP2 is much better.
    Redgum Television Productions
    Broadcast & Corporate Documentaries
    Brisbane, Australia
