Activity Forums Adobe Premiere Pro PP2 Freezing
  • PP2 Freezing
    Posted by Pat Ford on April 28, 2008 at 6:53 pm
    Premiere Pro seems to freeze whenever a particular subclip is played…it will play the master clip fine.
    Also, when I attempt play the subclip the memory use in Task Manager climbs to around 700k. Eventually it will go down and sometimes play, but this takes several minutes.
    Any ideas?
    Pat Ford replied 18 years, 4 months ago 2 Members · 2 Replies
  • Vince Becquiot
    April 28, 2008 at 11:24 pm
    I find this happened in PP2 on certain uncompressed, or Mpeg4 clips. Not much of a work around I’m afraid.
    Vince
  • Pat Ford
    April 29, 2008 at 4:55 pm
    Thanks to those that answered my post both via the forum and email.
    No thanks to the net nanny who emailed suggesting that I do a forum search first. Not having fallen off the turnip truck yesterday, I had already done so.
    Here is the work-around I used: open another project import the master clip. Razor back ’til you have the footage that was contained in the original subclip. Export. Import into original project.
    A bit tedious but not too bad.
