Activity Forums Adobe Premiere Pro PP2 Color Correction + Rescale causes field problem
  • PP2 Color Correction + Rescale causes field problem
    Posted by Alec Eves on July 6, 2006 at 7:02 pm
    I have been trying to get to the bottom of this little problem.
    I have 2 sequences, A feeds into B. I put a colour correction on the footage in sequence A, preview/render it and it plays out fine. I then go to sequence B where this colour corrected footage has a re-scale applied. Preview/render this sequence and suddenly it looks as though the field order of the clip has been changed. If it’s not changing the order then there is something very strange going on with the fields in the clip.
    I then tried putting the colour correction and rescale on the same clip in the same sequence, still the same problem occurs.
    I tried changing the field options for the clip but that seemed to have no effect on anything!
    I have been working in a PAL upper field project, though I did try a lower field project to see whether that would make a difference, but still got the same result.
    Has anyone else come across this problem or is it just me?
    Any help most appreciated
    Cheers
    Alec
    Alec Eves replied 20 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
