Activity Forums Adobe Premiere Pro PP2 closes when I try to burn DVD’s
  • PP2 closes when I try to burn DVD’s
    Posted by Tim Mccarthy on August 9, 2007 at 1:37 pm
    I insert blank disc, set up to export to DVD and click burn, and the program closes. Happened twice. It doesn’t crash the computer, it just closes out the program and I hear that little “bonk” sound that you hear when it won’t allow you to click something. I used it three days ago to burn 15 DVD’s and it worked great. Anyone?
    Tim Mccarthy replied 19 years, 1 month ago 4 Members · 4 Replies
  • Steven L. gotz
    August 9, 2007 at 2:55 pm
    Not enough info. Perhaps you need to go to a Windows restore point dated just after the successful burns.
    Steven
    https://www.stevengotz.com
  • Alex Udell
    August 9, 2007 at 3:07 pm
    Do you have Roxio Software installed?
    If so check in Add Remove Programs for a file called “Roxio DLA”
    This allows direct to disk dragging of files from the desktop, but it does conflict with Premiere Pro.
    Remove Roxio DLA.
    Reboot.
    Try again.
    After that, I got nuthin.
    Alex
  • Blast1
    August 9, 2007 at 5:58 pm
    Have you tried to re-create the Plug-in Cache File? If not, hold down the shift key when you start Ppro and hold it till the Project screen appears.
  • Tim Mccarthy
    August 13, 2007 at 7:39 pm
    Thanks, that worked.
