Activity › Forums › Adobe Premiere Pro › PP to Media Encoder best practices
Posted by Dave Fleming on July 1, 2011 at 4:18 pmIn my first experience working with Media Encoder, I simply dragged 2 60 second sequences from the Premiere project panel into Media Encoder. I’m guessing that’s not the best way to work, as it’s an absolute WAIT-FEST. Literally several minutes at a time, waiting for Media Encoder to accept the change in format from FLV to MPEG, several more minutes waiting to change the preset. And now that I’m finally ready to encode, even more minutes of “not responding”-style waiting. All files are local to my box, nothing is being referenced on a network. Please tell me what I’m doing wrong, because this isn’t exactly the “tight integration” between programs I was hoping for.
Dave
Dave Fleming replied 15 years, 2 months ago 3 Members · 10 Replies -
Chris Knight
July 1, 2011 at 4:27 pmAlthough I’ve never experienced wait times on that scale, I’ve found it’s quicker to open the sequence, and export it to the media encoder using FILE->EXPORT (hit queue, instead of export in the encoder settings). Compared to opening a sequence from within Media Encoder (without Premiere open), it’s much quicker.
However, once the sequence is in Encoder, I’ve never had delays. How much RAM do you have, and what’s you CPU?
Dave Fleming
July 1, 2011 at 4:54 pmI’m running a Dell T3500 with a Xeon 3.47GHz CPU and 12gb of RAM.
I tried what you suggested and it did speed things up. But, now I’ve got another problem. My sequence is SD NTSC Widescreen. I chose “match sequence settings” to keep things at their highest quality, and it created an AVI file. The problem is that the resulting movie is .91 aspect (not widescreen) even though everywhere I look in Media Encoder it says it will be 1.21. Any suggestions?
Chris Knight
July 1, 2011 at 6:57 pmWhat format are you trying to export? Your first post mentiones FLV and MPEG, and now you’re exporting a DVI-AVI. Let me know what you’re trying to accomplish, and I’ll walk you through the steps.
Dave Fleming
July 1, 2011 at 7:06 pmThanks–that would be helpful! I’ve spent the last few hours plugging in format after format, preset after preset, only to get the same results.
Here’s what I need to do: I have a 720×486 widescreen sequence. I used a sequence preset from my Matrox MXO2 LE box. Everything in the sequence is 1.21 PAR. I need to get it to a Harris encoder so the files can be encoded for air. The Harris will transcode almost anything you feed it, so it doesn’t really matter what I output: MPEG, AVI, QT…as long as it’s NTSC SD full resolution 1.21 PAR.
So, to my eye, I was getting the best results when I chose “match sequence settings,” which greyed most other parameters out. And indeed, if the output would match sequence settings, I’d be golden. But, the AVI that spits out is .91 PAR (4×3). I have no idea why.
Chris Knight
July 1, 2011 at 7:36 pmExport the movie, so it brings up the export settings. Uncheck the Match Sequence Settings box. For the format, pick anything you want. Let’s go with Microsoft AVI. Under Preset, choose NTSC DV Widescreen. Make sure Export Video and Export Audio are checked (they should be), and you’re done.
If you want a slightly higher-quality format, go with h.264, and choose NTSC DV Widescreen High Quality for the preset. This will take longer to render, if you don’t have Mercury Engine utilizing the GPU in your system, so try both and see which one produces better results.
FYI, most of the format selections have a DV NTSC Widescreen preset.
Dave Fleming
July 1, 2011 at 10:05 pmSorry man, you’re missing it. I’ve been trying yours and many other formats/presets all day. Every setting I can browse through says that the sequence will be rendered at DV Widescreen. Trust me, I’ve got that selected every way from Tuesday. But, my resulting movie, no matter whether it’s QT, AVI or MPEG (all selecting DV Widescreen) is always .91 PAR–i.e. NOT DV Widescreen.
Eric Sanders
July 1, 2011 at 11:10 pmHi Dave,
Could you post a screenshot of the AME encoder dialog and the sequence settings values you are using? That might help us see what’s going wrong.
-EricS -
Dave Fleming
July 2, 2011 at 2:24 amSure…I’ll post a few. First, the AVI attempt…
Now, a QT approach…
Here’s a screenshot when I attempt to “queue” instead of “export.”
And finally, the image is always seem to end up with…incorrect pixel aspect ratio!
And remember, I’m showing you two examples. I’ve tried literally dozens of variations. all with the same result. I’m to the point where I’m wondering if this isn’t somehow tied up with my Matrox sequence preset…?
Dave Fleming
July 5, 2011 at 9:57 pmI just wanted to add a final post to this thread. I began working with Matrox support in Montreal and they discovered that there was indeed a bug in the export to Media Encoder that would cause any Matrox sequence that happened to be 16:9 SD to be rendered 4:3. They are working on it. Thanks for your help, as always. For now, I’m just working in a DV NTSC Widescreen preset and bypassing Matrox altogether.
Dave
