  • Posted by Donato M. rondinelli on October 14, 2009 at 4:44 pm
    I have a mpeg2 clip from Premiere Pro, but I can’t play it in FCP 6. It was captured from tape through a Canon cam. The image in FCP is garbled. I have QT Pro with the mpeg plugin, but it just gives me a black screen. Streamclip will convert it, but I’d rather use it natively. I tried perain too, but that didn’t work.
    Can I not use a PP mpeg clip in FCP?
    -dMR
    Donato M. rondinelli replied 16 years, 10 months ago 4 Members · 8 Replies
  • 8 Replies
  • Donato M. rondinelli
    October 14, 2009 at 7:02 pm
    Hey Dave,
    I got the codec this morning. I installed, restarted & opened the file in QT Pro. Now instead of seeing a solid white screen, I see a solid black screen. That wasn’t worth $20 :o)
    FCP still has a garbled image flashing different colors without sound.
    Compressor just shows color bars.
    Streamclip will play it & convert it. I may have to go with that.
    The project/sequence is SD Kona uncompressed 8bit.
    Maybe premiere is doing something to the file that FCP doesn’t understand? Maybe something got screwed up in the install?
    -dMR
    October 14, 2009 at 7:21 pm
    I was on 7.6.2. I updated to 7.6.4 & reinstalled the plugin. No difference.
    The plugin says that it’s not compatible with mpeg transport streams. What is that? Is it a broadcast thing?
    -dMR
    October 14, 2009 at 8:14 pm
    Thanks for trying :o)
    -dMR
  • Rafael Amador
    October 15, 2009 at 1:30 am
    I Donato,
    You can try changing or deleting the extension,
    You wont be able to play the audio in FC because, I guess, is MP2.
    FC works with QT files. It can cope with certain kind of MPGs only.
    Don’t waist your time and transcode to 8b Unc.
    BTW, the Apple MPEG-2 component is unnecessary if you have installed Compressor or DVDSTP.
    rafael
    http://www.nagavideo.com
    October 15, 2009 at 1:45 am
    Yea, and PP is one of those unrecognizable mpegs. I did transcode but I forgot about the whole long GOP thing. The guy captured the whole 40 minute interview in PP to 1 file & gave it to me. After the transcode, my audio was out of sync. Fortunately I had him export a QT DV file from PP too. I loose the cool pan & scan feature but at least I have audio in sync.
    -dMR
  • Dennis Radeke
    October 16, 2009 at 10:24 am
    Try using Premiere Pro to convert the file to something FCP can read. Depending on the version you are using, you could probably convert it to ProRes without much difficulty.
  • Graeme Benson
    October 26, 2009 at 3:10 pm
    Hi
    Could you tell me please HOW to convert mpeg2 to pro ress 422?
    I use fcp7 mac os x 10.5.8
    thanks
    Graeme Benson
    October 26, 2009 at 3:20 pm
    This is how it’s done in ver 6, not sure about 7.
    You’ll need to do it in compressor. Open the program & go to settings. In the folders, go to: Apple/Format/Quicktime. Drag & drop the Apple ProRes 422 setting on your clip.
