PP Import Question…
A pretty simple question.
It’s common sense that two different resolution clips on a set sequence would cause playback issues. Example, I create a sequence for 1080p. I lay down 1080 clips, all requiring no rendering….however when I lay down a 720 clip, the timeline render indicator goes red. Can’t watch it without rendering the entire work area.
In Final Cut, however, I can lay down both 1080 and 720 in the same sequence without playback issues, or needing to stop work, and render.
Can someone explain why FCP handles this so gracefully compared to PP, and if PP is actually capable of the same thing?
Hunta—–
Too bad she won’t live! But then again, who does?
-Gaff
