Activity Forums Adobe Premiere Pro PP Debug Event [….SrcPictureButton.cpp-204]
  • PP Debug Event [….SrcPictureButton.cpp-204]
    Posted by Jason Tamimi on January 21, 2011 at 5:09 am
    I’m running Premiere Pro CS5 on Win7 Ultimate 64bit. I’ve had no issues with Premiere. recently I’ve been receiving this error message on startup.
    PP Debug Event: Premiere Pro has encountered an error. [..\..Src\PictureButton.cpp-204]
    I have the option to continue. When I click continue everything works fine. Googling the error hasn’t been fruitful. Any thoughts on what is causing this error and possible solutions?
    I upgraded PP to 5.0.3. and restarted my machine to no avail.
    Josh Prescott replied 13 years, 8 months ago 3 Members · 6 Replies
  • Alex Udell
    January 21, 2011 at 3:21 pm
    every project? a particular project?
    Alex
  • Jason Tamimi
    January 21, 2011 at 8:02 pm
    every project. I started a couple of new projects to see if the project was corrupted but I’m still getting the message.
  • Jason Tamimi
    January 22, 2011 at 1:24 am
    I was able to isolate the problem. When I create a new project and save the project on my desktop, I get no errors. When I create a new project and save the project to an external HDD I get the error every time. I cleared the media cache through premiere but that didn’t solve the problem. I’m wondering if there’s a file somewhere with cached data that’s causing the problem.
  • Jason Tamimi
    January 22, 2011 at 5:56 am
    SOLVED –
    I navigated to
    C:\Users\username\Documents\Adobe\Premiere Pro\5.0
    Deleted everything in the folder.
    Restarted Premiere and the error didn’t return. I obviously lost some settings by deleting these files but not a big deal.
  • Alex Udell
    January 22, 2011 at 9:06 pm
    cool
    Alex Udell
    Editing, Motion Graphics, and Visual FX
    Chumney & Assoc. Advertising
  • Josh Prescott
    January 25, 2013 at 9:06 am
    I have found the culprit file!!! 🙂
    Its [Effect_Presets_and_Custom_Items.PRFPSET] located in
    “C:UsersUsernameAppDataRoamingAdobePremiere Pro”
    Delete that and restart.
    Apparently the newer Premiere builds dont like new projects to be made and loaded up after previous custom presets are made.
    I have noticed it only does this on projects I have made AFTER creating presets.
    Hope that helps out gentlemen
