Activity Forums Adobe Premiere Pro PP CS5.5 Track Matt changes size in pause
  • PP CS5.5 Track Matt changes size in pause
    Posted by Andy Milne on May 10, 2012 at 12:54 am
    In premiere cs5.5 I have a quicktime 1080 animation that I am overlaying using a PSD file as a track matt on an PAL 720×576 sequence. When I play the track matt works fine but as soon as you stop the track matt drops about 20% in size. I tried the same project in Premiere cs5 and the matt works fine without changing size in stop.
    Anyone else come across this?
    Cheers
    Andy
    Andy Milne replied 14 years, 3 months ago 1 Member · 1 Reply
  • Andy Milne
    May 10, 2012 at 1:06 am
    Just found that if I make a 1080 sequence for the animation and track matte, so seq matches animation and PSD, then nest and scale over my main PAL sequence then it works fine.
    Still looks like a bug though as it worked in CS5.
