Activity › Forums › Adobe Premiere Pro › PP CS5 Advice on setting up sequence for DVD project, using 4 different formats as footage
  • PP CS5 Advice on setting up sequence for DVD project, using 4 different formats as footage
    Posted by Ed Wyllie on December 28, 2012 at 8:58 pm
    I am trying to put together a DVD and hopefully also output for live streaming. Using footage from 4 different sources, GoPro MP4, 1280×960, 29.97, 1.0 / Canon DSLR .MOV 1920×1080, 20.97,1.0 /
    .MTS, 1920×1080,29.97,1.0 / .MTS, 1440×1080,29.97,1.3333.
    I will be using the GoPro MP4 footage the most out of the 4 so figured I would set sequence up to match that then scale the other formats to fit. Although not sure if this is best option for outputting to DVD or if my machine will even handle 4 varied formats in 1 sequence, MacPro, 2Ghz, Intel core 17, 8gb DDR.
    Any help would be much appreciated, thanks for your time!
    Ed Wyllie replied 13 years, 9 months ago 2 Members · 2 Replies
  • Angelo Lorenzo
    December 29, 2012 at 10:35 pm
    So:
    MP4 1280×960, 29.97, 1.0
    MOV 1920×1080, 20.97, 1.0
    MTS 1920×1080, 29.97, 1.0
    MTS 1440×1080, 29.97, 1.3333
    I assume it’s a typo and you meant 29.97 for the Canon footage? The camera can’t do a frame rate like 20.97, but I want to eliminate the possibility that you did some kind of bad pre-conversion.
    I think your best bet is a 720p 29.97 sequence(1280×720). All the 1080 footage can be scaled down nicely.
    GoPro’s 1280×960 is a non-standard format. There could be a few reasons for using it, but it mostly comes down to using it as standard 720p with the ability to recompose the shot vertically if needed. In other words, you’ll need to crop some off the top and bottom for it to be a standard 16:9 viewing size.
    In regard to the 1440×1080, this is a recording and not a viewing format. Premiere Pro should automatically de-squeeze the footage; you’ll be left with what is, effectively, a 1920×1080 frame.
    From the 720p file you can easily upload it as-is to video sites or convert it out to a widescreen dvd format without issue.
    All the footage is h.264 or a subset (AVCHD for instance) so you shouldn’t have huge playback issues at 1/2 or 1/4 resolution. If it’s a large project I would consider using an intermediate codec just because they scrub more smoothly; it could be an overall time saver.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
  • Ed Wyllie
    December 30, 2012 at 6:18 am
    Thanks Angelo, yes was a typo.
    So my best option would be the AVCHD 720p preset?
    Your advice has been much appreciated.
