Activity Forums Adobe Premiere Pro PP CS4 capture from Sony PD170
  • PP CS4 capture from Sony PD170
    Posted by Corey Ging on May 1, 2009 at 3:21 am
    We have two Sony PD170’s and have began capturing in Premiere Pro CS4. I’m new at this so I might be missing something, but the quality that I get is pixelated and not that great. I have heard that this camera is used on ‘professional’ shoots for MTV etc, but I am not getting that from it.
    Any direction on settings in Premiere Pro CS4 that would result in better looking footage? Is there a difference in firewire cables? So far I have tried capturing ‘uncompressed’ because I thought it would be the best looking, but so far no luck.
    Thanks in advance.
    Corey Ging replied 17 years, 3 months ago 3 Members · 6 Replies
  • Mike Velte
    May 1, 2009 at 10:40 am
    Capturing via firewire is simply data transfer with no changes made to the data other than;
    1. Dropped frames
    2. Dirty playback head on the camera
    3. Tape defects
  • Ann Bens
    May 1, 2009 at 6:52 pm
    Make sure you are in the right project settings: ntsc/pal dv standard or widescreen 48 kHz.
  • Corey Ging
    May 2, 2009 at 1:11 am
    *Is there a head cleaner that you recommend or all they all the same?
    *Other than cleaning the head, what can help to reduce dropped frames?
    *I have the project settings:ntsc/dv widescreen 48 kHz. What about compression when ‘digitizing’? Any other settings that might be wrong?
    I have another PD170, that I will try to use on Monday. It has less hours and I will see if I get better quality from it.
  • Mike Velte
    May 2, 2009 at 10:32 am
    Try to recapture the footage with your other camera.
  • Ann Bens
    May 2, 2009 at 7:19 pm
    Its a Sony camera so use a Sony cleaning tape.
  • Corey Ging
    May 8, 2009 at 3:28 pm
    So in the capture settings, I was using ‘uncompressed’. Someone who knows more than I do looked at the files. He recommended capturing with the DV compression.
    That works great and is much smaller.
