Activity Forums Adobe Premiere Pro PP CS4 Audio Sync Issue
  • PP CS4 Audio Sync Issue
    Posted by Michael Schnyer on January 21, 2010 at 7:54 pm
    I am using Premiere Pro CS4, and am working on an HD project in 30F. I have captured about 20 or so tapes am have been editing furiously, and long story short, SOMETIMES when I put my footage files from the bin into my timeline there is an audio sync problem. I can play the base files in VLC just fine.
    There are some unusual characteristics to this. Sometimes it is noticeable when I first scrub through the footage, but most times it is NOT present and will appear after having closed the program and opened it again later, or even several times later.
    Also, it is not a gradual delay, I can usually pinpoint the part of the clip where the audio goes from in sync to out. So far as I can tell this always happens when my footage cuts from one shot to the next, but that might not be accurate since this problem usually happens after I’ve already cut a full scene.
    Last, and most importantly: there have been several instances where I caught out of sync audio BEFORE I made a cut, adjusted it and cut the scene, and then later the audio was BACK in sync (effectively screwing up my edits). What’s up with that?
    Any help is much appreciated, I have a looming deadline!
    Michael Schnyer
    Aspiring Filmmaker and Editor
    Canon XH-A1
    After Effects
    Premier Pro
    3DS Max
    Chris Macneil replied 16 years, 7 months ago 3 Members · 3 Replies
  • James Barr
    January 22, 2010 at 8:55 pm
    I’ve had the same problem working with H.264 files with a .m2ts extension. (along with different problems in other pro-level video editing programs) If that’s what you’re working with…I’ve found no real solution except re-encoding the file before you even start working with it.
  • Michael Schnyer
    February 1, 2010 at 11:30 pm
    Thanks for the response, I’ll see if I figure anything useful out.
    Michael Schnyer
    After Effects
    Premier Pro
    3DS Max
  • Chris Macneil
    February 10, 2010 at 2:54 pm
    Hi Mike
    I wondered if you managed to get any further with the audio sync problem I am using CS4 and have 32 hours of HDV imported and am finding half way through the tape the sync slips its ..not good
    did you find any fixes
    thanks
    Chris
