Activity Forums Adobe Premiere Pro PP-CS3 mpeg-4 audio drop
  • PP-CS3 mpeg-4 audio drop
    Posted by Brian Reitz on May 17, 2008 at 12:50 am
    I am using Premier Pro CS3 and was asked to edit 4 mini DVD’s from a school event. I converted the VOB files with TMPGEnc 4.0 XPress into avi files, but so large made PP run very slow. I then converted to MPEG-4 and I imported that into PP. However when it gets around 8-12 minuets into the video the audio drops out completely. I have checked the original, and there are no audio problems. Is there a setting that I am over looking? They all seem to kill the audio at around the same time. Thanks for your help, Brian
    Shannon Wilkerson replied 17 years, 12 months ago 3 Members · 2 Replies
  • Mike Velte
    May 17, 2008 at 11:09 am
    Mpeg 4 files are not suitable for editing…at least in CS3. Convert your VOB files into DV.avi (type 2).
  • Shannon Wilkerson
    September 27, 2008 at 5:13 am
    Can you go into specifics why. I am also working on a project where the footage was shot from a Sony xdcam and the file format is mpeg-4. I am trying to play my clips in PP and I am dropping frames and audio.
    Shannon Wilkerson
    Denver, CO
