Activity Forums Adobe Premiere Pro PP CS3 – mixing 16:9 & 4:3 ??
  • PP CS3 – mixing 16:9 & 4:3 ??
    Posted by Tim Taylor on March 30, 2008 at 9:18 pm
    I live in the UK where we use PAL, if that has any bearing on my problem.
    I have been given footage to edit from 2 different cameras, one a widescreen, the other 4:3 – i know not the spec of the cameras, all I know is some of the footage is widescreen, and the rest is not.
    If I edit this footage in a PP CS3 project that is set as DV PAL Standard (i.e. 4:3) will the widescreen footage be automatically adjusted on the export to AVI after editing?
    I want to avoid resizing within PP CS3 at all costs if I can!
    Advice please!
    Jon Barrie replied 18 years, 5 months ago 2 Members · 1 Reply
  • Jon Barrie
    March 30, 2008 at 10:19 pm
    You should be able to mix the 16:9 footage into the 4:3 project no problems. So long as you interpret the Pixel Aspect Ratio (PAR) as 16:9 widescreen.
    Don’t adjust the width scale in Motion, the clip should cut off the side if it has been interpreted properly (as 16:9).
    When you export you need to be sure to do it with the 4:3 aspect ratio and pixel sizes. (PAL 720×576 PAR 1.067) (NTSC 720×486 PAR 0.9)
    – Jon 🙂
    How many editors does it take to change a light bulb?
    http://www.jonbarrie.net
