Activity Forums Adobe Premiere Pro PP Corrupting footage it seems…?
  • Ann Bens
    January 5, 2013 at 1:02 pm
    Trash your preferences and media cash database and import again.
    See if that will help.
    Which camera?
    Adobe Certified Expert Premiere Pro CS6
    Adobe Community Professional
  • Tero Ahlfors
    January 5, 2013 at 5:00 pm
    What format/codec does the camera shoot in?
  • Chris Tompkins
    January 9, 2013 at 12:02 am
    Your links do not work.
    Chris Tompkins
    Video Atlanta LLC
  • Camille Katz
    January 9, 2013 at 10:33 pm
    Hi Chris,
    Sorry! i didn’t think anyone else would answer this post so i removed them.
    here they are again:
    https://www.flickr.com/photos/90544058@N02/8365005093/in/photostream
    https://www.flickr.com/photos/90544058@N02/8365005101/in/photostream/
  • Camille Katz
    January 9, 2013 at 10:39 pm
    Hi Ann
    Thanks a lot for your time to reply!
    I cleaned (that’s the same like trashed right?) my media cash database and imported it again but still the same issue persists.
    My camera is a simple little handheld thingy. A Sony DSC-W50 with a 25fps.
    Do you think its the camera’s fault?
    It seems ok when i play it back anywhere else but in Premier Pro.
    I’m rather confused what the problem is.
    Thank you again
    Camille
  • Camille Katz
    January 9, 2013 at 10:45 pm
    ehm i’m not quite sure. its a little simple thingy.
    in my camera settings it says Sony, 480p, 25fps, standard STD.
    Sorry i’m not so knowledgeable with these things!!
  • Tero Ahlfors
    January 10, 2013 at 5:25 am
    That seems to be a pretty old camera that shoots MPEG1 video which is an outdated format. Also the STD setting shoots in 16,6 frames a second (the FINE setting seems to shoot at a more standard frame rate of 30fps) so that will be a/is probably the problem.
  • Chris Tompkins
    January 10, 2013 at 11:53 am
    I see those bands in AVCHD footage now and again, It’s just on the computer screen in Premiere, don’t worry about it. Export to your deliverables and all will be fine.
    Chris Tompkins
    Video Atlanta LLC
  • Camille Katz
    January 10, 2013 at 2:06 pm
    Hi Chris,
    I thought that might be the issue too but even after i export it it comes out in the final result with those bars still.
  • Chris Tompkins
    January 10, 2013 at 2:20 pm
    Wow, really?
    Does your sequence match your footage?
    What are you compressing to?
    Chris Tompkins
    Video Atlanta LLC
