Activity Forums Adobe Premiere Pro PP CC Imports fottage at half frame rate
  • PP CC Imports fottage at half frame rate
    Posted by Robb Bomboy on May 28, 2014 at 6:09 pm
    I have a student who bought PP CC. We use PP CS6 in class.
    She has 1920 x 1080i footage 29.97 .
    She imports into PP CC , the clip comes in as 14.99 fps
    It plays in slowmotion.
    I import into pp CS6 , The same clip come in as 29.97fps
    It plays in real time.
    What has she done? She’s a newbie.
    Jesse Chandler replied 11 years, 4 months ago 4 Members · 3 Replies
  • Alex Udell
    May 28, 2014 at 6:13 pm
    Probably nothing wrong. She might try using media browser panel instead of import or drag and drop from the OS to see if she gets’s a different result.
    Footage should be able to be interpreted in the project panel and set to the correct rate if those approaches don’t resolve it.
    Alex Udell
    Editing, Motion Graphics, and Visual FX
  • Joe Weber
    March 2, 2015 at 8:07 pm
    There is definitely something wrong. I am having the same problem: A clip which is actually 29.97 fps (verified using QT properties) is importing as 1/2 framerate, or 14.985 (rounded up to 14.99) fps. This happens with several of my clips, regardless of the import method used (drag/drop from OS, right-click/import, or use Media Browser). I cannot interpret the footage back to 29.97, as doing so doubles the speed of the audio (an interview), making it unusable.
  • Jesse Chandler
    May 5, 2015 at 5:23 pm
    Just found a fix for this. Open in quicktime, and select File>Export>1080p. It takes a few minutes, and likely degrades the quality a bit, but at least it fixes the frame rate issue.
