Activity › Forums › Adobe Premiere Pro › PP CC 2017 Unable To Add B Roll To Multicam Sequence
  • PP CC 2017 Unable To Add B Roll To Multicam Sequence
    Posted by Ashley James on June 24, 2020 at 7:37 pm
    I’m cutting a 6 camera multicam sequence in CC 2017. When I add b roll on the track above, the multicam display in the Program Monitor disappears and is replaced by a double image of whatever was the last angle in the sequence I chose. Itnever returns to the multicam format. Very difficult to cut this way if I want to use cutaways. Any suggestions on how to remedy this?
    A.James
    Herb Sevush replied 6 years, 3 months ago 2 Members · 1 Reply
  • Herb Sevush
    June 25, 2020 at 12:39 pm
    Ashley –
    The multicam viewer always shows clips from the lowest active track. If you have track 1 and track 2 active, with multicam elements on track 1, then when you add B-roll (which I assume is not part of a multicam source ) on track 2 the Multicam viewer (left side of the double image screen) should continue to show whatever was placed on track 1, while the Sequence viewer (right side of the screen) will show the B-roll cut in as you intended.
    When laying in single source B-roll it’s often better to disable the multicam viewer (I believe the toggle for that is shift-0 ).
    Herb Sevush
    Zebra Productions
    nothin\’ attached to nothin\’
    \”Deciding the spine is the process of editing\” F. Bieberkopf
