Activity › Forums › Adobe Premiere Pro › PP CC 2014 Importing .mov issue
  • PP CC 2014 Importing .mov issue
    Posted by Jim Collins on July 29, 2014 at 11:49 pm
    Here is an odd issue that has turned up. When I click and drag a .mov file to a sequence – no audio track shows. If I click and drag the same .mov file to make a sequence directly – the audio track shows up in the sequence. In CS6 PP – if I click and drag the same .mov file to a sequence – the audio file shows up in the sequence.
    If I right click the .mov file in the project window I can edit it in Audition even though no audio track shows in a sequence and it makes an Audition extracted track, which I can then add into the sequence.
    Is this another “feature” from Adobe or somehow a “feature” of my system??
    I like the way it worked in CS6 PP – if it is a new “feature” from Adobe, I don’t like it at all!!!
    Any thoughts as to what is going on??
    Note: Not that it should matter but the .mov files are coming from a little point and shoot Nikon S8200 with 1080p/30fps that I use mostly for fun.
    Thanks!!
    Jim Collins
    Jim Collins replied 12 years, 2 months ago 2 Members · 7 Replies
  • 7 Replies
  • Kevin Monahan
    July 30, 2014 at 1:10 am
    Hi Jim,
    Load the clip into the Source Monitor. Check your Timeline. Is your Timeline patched correctly? If so, try it again. If not, patch it correctly, then drag/drop.
    Kevin
    Kevin Monahan
    Support Product Manager—DVA
    Adobe After Effects
    Adobe Premiere Pro
    Adobe
    Follow Me on Twitter!
  • Jim Collins
    July 30, 2014 at 1:11 am
    Followup to 1st post –
    Same thing happened with a Canon .mov file.
    Jim Collins
    JJC
  • Kevin Monahan
    July 30, 2014 at 1:15 am
    Were your tracks patched?
    Kevin Monahan
    Adobe After Effects
    Adobe Premiere Pro
    Adobe
  • Jim Collins
    July 30, 2014 at 1:18 am
    Kevin –
    Not sure what you mean by “Is your Timeline patched correctly?”
    Double clicking the clip plays the clip in the source monitor with audio – when I insert the clip from source monitor into the sequence – the audio vanishes.
    In CS6 PP – using the same sequence properties it works just fine.
    Jim Collins
  • Jim Collins
    July 30, 2014 at 6:24 pm
    For those of you that don’t know about patching tracks and other stuff – see this link – it was very helpful:
    https://helpx.adobe.com/premiere-pro/using/source-patching-track-targetting.html
    Jim Collins
  • Kevin Monahan
    July 30, 2014 at 10:36 pm
    Following up: I assume that your tracks were not patched properly?
    Kevin
    Kevin Monahan
    Adobe After Effects
    Adobe Premiere Pro
    Adobe
  • Jim Collins
    July 30, 2014 at 10:55 pm
    Correct – in past versions (CS6) I had not run into this – so it surprised me. I had to search out what you were talking about “patched tracks”. Not sure if I like it or not – maybe once I get used to it I’ll learn to love it.
    Thanks for pointing out what I needed to research.
    Jim Collins
