Activity › Forums › Adobe Premiere Pro › PP and AJA cards
  • PP and AJA cards
    Posted by Brian Scott on May 29, 2008 at 3:45 pm
    I’m looking to put together a system using an AJA card for I/O. All my inputs will be SDI. Will the Hs card work as well as the LHe?
    Brian Scott
    President
    Image Design Productions, Inc.
    Tim Kolb replied 18 years, 4 months ago 3 Members · 3 Replies
  • Tim Kolb
    May 29, 2008 at 7:54 pm
    The HS card was designed as an “OEM” card really…something that could be (relatively) inexpensively bundled with certain software and/or hardware to get HDSDI I/O on a system…
    The HS card does NOT have:
    HD analog component I/O
    SD analog component or composite/YC I/O
    Hardware HD to SD downconversion (I use this all the time)
    Native support for DPX, Cineon, TGA, TIFF, BMP sequences
    2 independent SDI/HD-SDI outputs (The HS card has only 1)
    2-channel balanced XLR analog audio I/O
    RS-422 machine control
    AJA Machina software
    For the money, I think the LH/LHe cards are a better return on investment for a general-purpose editing suite that may switch back and forth between SD/HD…uncompressed/compressed, etc…
    In a very narrow application where you knew you’d always only need digital HD I/O…the HS would probably be fine.
    TimK,
    Director, Consultant
    Kolb Productions,
    CPO, Digieffects
  • Steven L. gotz
    May 29, 2008 at 9:23 pm
    I have an LHe card I won in a drawing that I have never used. I suppose I need to install it one of these day, huh?
    Steven
    https://www.stevengotz.com
  • Tim Kolb
    May 30, 2008 at 1:12 am
    [Steven L. Gotz] “I have an LHe card I won in a drawing that I have never used. I suppose I need to install it one of these day, huh?”
    They are intensely useful tools…I use the matrix of inputs and outputs differently every day. Realtime downconvert to SD means I can edit in HD and send to my BVM SD reference monitor via SDI and use my SD scopes via analog to monitor what a downconvert will look like (most regional commercials still run in SD).
    TimK,
    Kolb Productions,
    CPO, Digieffects
