Activity Forums Adobe After Effects PP and AE workflow
  • PP and AE workflow
    Posted by Joe Parsons on April 9, 2014 at 3:28 pm
    I’ve been using Premiere Pro CS4 for three or four years. As I start to tackle more ambitious projects, I can see the value of the additional features in After Effects.
    My typical project is a short sales or training video, shot against a green screen. I record audio separately and sync it in PP.
    What is the most efficient way to take advantage of the AE feature set? Should I do my basic editing in PP, then do the rest of the editing (keying, titles, etc.) in AE? Or is it better to render in PP and create a fresh project in AE?
    Joe Parsons
    Stephen Smith replied 12 years, 5 months ago 3 Members · 4 Replies
  • Michael Szalapski
    April 9, 2014 at 4:14 pm
    It sounds like the best thing to do would be to import your Premiere project into AE. That way your edit is maintained, but you have access to all of the original footage and cuts.
    Then you can do your titles and compositing in After Effects, render a lossless (or near enough) intermediate and then render it out to your final deliverable in the Adobe Media Encoder. Alternatively, you can just send your AE composition directly to the Adobe Media Encoder.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Stephen Smith
    April 9, 2014 at 5:37 pm
    [Michael]
    That is what I do. Premiere is much better for editing your project and trying out different takes and adjusting the overall pacing of the video. For example, I cut this spot in premiere and then imported (dynamic link) the edited footage into AE and then did my rotoscoping, graphics, etc. to make the completed spot:
    https://vimeo.com/76003006
    Watching the side by side of the spot will give you an idea what I’m talking about. Everything on the left side was put together in Premiere. Everything on the right side was then sent to AE and DaVinci Resolve to create the completed look.
    https://vimeo.com/76622200
    Hope this helps and best of luck.
    Stephen Smith
    Utah Video Productions
    Check out my Vimeo page
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Joe Parsons
    April 15, 2014 at 11:22 pm
    Thank you SO MUCH for this! It’s just what I needed!
    Joe Parsons
  • Stephen Smith
    April 16, 2014 at 4:06 pm
    Happy to help. Best of luck.
    Stephen Smith
