Activity Forums Adobe Premiere Pro PP 1.5 vs Premiere 6.5: Export Times, AMD X2
  • PP 1.5 vs Premiere 6.5: Export Times, AMD X2
    Posted by David Loschiavo on February 26, 2006 at 10:43 pm
    A couple of observations:
    I conducted a few export tests on a PP 1.5 and AP 6.5 and wanted to solicite comments from the group. I have not switched to PP 1.5 yet, but I am considering it. I am only a serious hobbyist, not a professional.
    This is a good example of the results I am getting. I applied a video filter (Shine) to a 45 minute video file, using the same settings in both platforms (DVD high quality – Default)
    Results: PP 1.5: 40 minutes
    AP 6.5: 25 minutes
    On a separate note: I noticed you can capture video in P-Pro and still run other programs. In AP 6.5 when I am capturing I cannot use the machine, if you try to run another App the capture stops. Is there an override in AP 6.5 for the capture isolation of the machine?
    Also, is anyone using a computer similar to what I have below? I don’t know if P-Pro has been optimized for Pentium and that is why I am seeing the different results above on the AMD machine I have.
    Computer Specs:
    AMD Athlon 64 X2 4400+ 1GHz FSB Socket 939 Dual Core Processor
    ABIT AN8-ULTRA Socket 939 NVIDIA nForce4 Ultra ATX AMD Motherboard
    Western Digital Caviar SE16 WD3200KS 320GB 7200 RPM SATA 3.0Gb/s Hard Drive
    SAPPHIRE Radeon X800GTO 256MB GDDR3 PCI Express x16 Video Card
    Creative Sound Blaster Audigy2 ZS 7.1 Channels PCI Interface Sound Card
    CORSAIR XMS 2GB (2 x 1GB) 184-Pin DDR SDRAM Unbuffered DDR 400 (PC 3200)
    Western Digital Caviar 250GB 7200 RPM IDE Hard Drive
    Western Digital Caviar 120GB 7200 RPM IDE Hard Drive
    FSP Group AX500-A PSU
    David Loschiavo replied 20 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
