Activity › Forums › Adobe Premiere Pro › PP 1.5 Can I add The same transition to 10 clips at one time
Posted by Mark Perez on April 6, 2006 at 1:30 amCan I add The same (dip to black) transition to 10 clips at one time
Struggling to figure this out
thanks for the help
markJoe Edwards replied 20 years, 5 months ago 5 Members · 6 Replies -
Steven L. gotz
April 6, 2006 at 3:16 amNo. You can’t. Not unless you use “Automate to Sequence” to put the clips on the sequence.
You can use the Page Down key to get to the cut and use Ctrl-d to put the default transition in.
Tony Neal
April 6, 2006 at 6:22 pmYou could use the Effects Control window to set keyframes and opacity levels on the built-in opacity effect for the first clip, then save it as an opacity preset. You can just drag and drop the effect on to any clip, thereafter.
Tone
Mark Perez
April 7, 2006 at 3:39 amIs it possible to do this in PP2.0 ? Im considering the upgrade,
So again 10 clips in a row on video 1 can I apply a transition to all selected at one time in PP 2.0
Or what program if any NLE can ?
much appreciated the prevoius replies
thanks
mark -
Craig Howard
April 7, 2006 at 10:01 amPremPro 2 – No you cant.
BTW: By the time you have finished discussing it you could have done it.
Its an operation that only takes seconds for ten clips. ( I could do it it in less than 45 secs)
Steven L. gotz
April 7, 2006 at 7:32 pmPretyy much the Page Down and Ctrl-D alternating can do one heck of a lot of transitions very quickly.
Joe Edwards
April 13, 2006 at 7:26 amFinal Cut can do this (w/drop zone thingie in comp window), but it’s not a feature per se.
Of course it doesn’t take much time in Premiere with shortcuts.
-j
