Larry Watts
August 21, 2008 at 8:11 pmNo one mentioned the added problem of getting the “builds” or animated bulleting to video, or the powerpoint transitions.
Most powerpoints today have a lot of movement which makes a transfer more complex.
Larry
Larry Brewer
August 21, 2008 at 8:35 pmYou are absolutely correct. Been there. Sometimes you just want to put a camera in front of the monitor…
I assumed he was referring to stills since he mentioned “slideshow” and the Shift/printscreen method I mentioned does work very well.
For the purpose of capturing powerpoint animation and builds I recently purchased Presentersoft PowerVideoMaker.
https://www.presentersoft.com/download.htm
I’ve only used it once but recall it performed very well. It might be the ticket.
