Activity Forums Blackmagic Design Powering off ATEM Television Studio
  • Powering off ATEM Television Studio
    Posted by Jake Schumacher on February 29, 2012 at 12:49 am
    Cheers,
    I just installed an ATEM Television Studio switcher and I haven’t found anything in the manual on how to power it off besides cutting power. I have it mounted in a rack connected to a power condition that I have been shutting off when I’m done but I just want to double check that this is the correct way to shut it down.
    Sean Verwey replied 6 years, 10 months ago 3 Members · 3 Replies
  • Justin Strauber
    February 29, 2012 at 1:05 am
    There is no on/off switch. If you want to turn it off, then as you’ve found, just cut the power.
  • Jake Schumacher
    February 29, 2012 at 1:10 am
    Thanks Justin. I haven’t used many devices that shutdown this way and didn’t want to ruin a new piece of gear.
  • Sean Verwey
    October 13, 2019 at 4:52 am
    This is an old post, so does this also apply to the newer ATEM TV Studio Pro HD unit (and I assume the 4K version)?
    At the moment, I leave the desk running all the time, but would prefer not to, as it is sucking in more dust than I’d like!
