Activity Forums VEGAS Pro Powerfull 3d Card for Vegas – Facing Problems :(
  • Powerfull 3d Card for Vegas – Facing Problems :(
    Posted by Accountclosed on November 25, 2005 at 1:39 pm
    infact i have “ASUS AX EXTREME 600 Pro” so i am facing problems to applying effects in vegas (3d effects) whenever i apply any effects(that contains high graphics or you know what i mean) i am facing problems to view.
    however i came to know that Matrox RTX 100 Extreme Pro is the Best for Editing
    can anyone from you tell me that if i buy the ASUS RTX 100 EXTREME PRO that can help me to stop facing the prob or not ?
    one more thing someone told me that i should have atleast a 3dcard (*like as i also have Asus Ax 600 Pro Extreme*)to use with Matrox RTX 100 Extreme Pro
    i mean do i realy need another card with RTX 100 EXTREME PRO ?
    Thanks for your time
    Regard,
    ALi
    James_j replied 20 years, 10 months ago 5 Members · 6 Replies
  • Peter Wright
    November 25, 2005 at 2:18 pm
    Although Vegas has it’s own 3D compositing, it deals with 2D frames and brings everything back to a 2D plane. It cannot, as far as I know, take any advantage of a 3D graphics card, in fact it will probably work worse with one.
    Peter Wright
    Perth, Western Oz
    http://www.allroundvision.com.au
  • Jeremy Rochefort
    November 25, 2005 at 3:13 pm
    An ultra high end graphics card will not speed up your preview process. What will speed up your preview is raw cpu power. As you add transitions, cross-cuts etc, so you will slow down your preview.
    Vegas does not make use of gpu hardware accelaration so a high end graphics card will be to no avail.
    One way of speeding up your preview is to reduce the preview quality in the preview window. Don’t forget than you can also use “build dynamic ram preview” which will render a selection to ram so that you can view in real time what the final product will look like.
    Cheers
    Jeremy
    MJ Productions
    MJ Productions
  • Accountclosed
    November 25, 2005 at 5:01 pm
    thanks for your tips and your time but one more thing can you tell me plz if i just buy a RTX 100 Extreme Pro for this reason (Preview Problem) do you mean its Useless ? i mean waste of money . coz in my country its very expensive card and i was just gonna buy this card for this problem. infact when i save the video with effects this also take time on 3d or high graphic effects in video *** i have Intel Pentium 3.2 multi processor and 1024 GB Ram and Asus AX 600 Pro Extreme in PCI 2 Slot .
    Thanks for all your help
    ALi
    Creative Cow is the best forum for communicate*
  • Edward Troxel
    November 25, 2005 at 5:30 pm
    Vegas is not designed to use external hardware cards to speed up renders and previews. All you need is a standard firewire card. If you want to use the Matrox RTX100, you’ll have to use Premiere. With Vegas, that card is totally unnecessary and will not be used.
    Edward Troxel
    JETDV Scripts
  • Accountclosed
    November 26, 2005 at 5:19 am
    Thanks for All your time infact thanks in advance
  • James_j
    November 29, 2005 at 6:11 am
    We found it to be useless. Well, _worse_ than useless since it forced us to use Premiere. You should have been around a few months back when we sold it for half the cost (and were glad to unload it).
