Activity Forums DaVinci Resolve Power Windows not behaving
  • Power Windows not behaving
    Posted by Dimitrios Papagiannis on September 26, 2011 at 3:49 am
    i am having a problem with the power windows.(i am also having a problem with being able to make a capital i) anyway…
    Whenever i make a power window and try to adjust its points/softness using the mouse get this “snap back” type of reaction. in other words whenever try and pull out a window using its points they don’t stay where want them. The line and point wants to snap back to its original position. Sometimes they do stay but not for the most part. i am also using a Wave.
    Sascha Haber replied 14 years, 11 months ago 3 Members · 5 Replies
  • Dimitrios Papagiannis
    September 26, 2011 at 4:04 am
    Sorry maybe i should add that this problem might have had something to do with the fact i was doing to 3d Footage. i believe that was on the Gang-Left eye setting.
    Thanks again
  • Charlie Edison
    September 26, 2011 at 4:46 am
    The only reason this would be have like such is if you were parked inside a track nonde dissolve, you can only adjust either side of the transition.
  • Sascha Haber
    September 26, 2011 at 8:31 am
    The other reason could be that there is animation on the window and you try to change it in-between two key-frames.
    A slice of color…
    DaVinci 8.0.1 OSX 10.7
    MacPro 5.1 2×2,4 24GB
    RAID0 8TB eSata 6TB
    GTX 470 / GT 120
    Extreme 3D+ WAVE
    http://www.saschahaber.com
    September 27, 2011 at 7:20 am
    Thanks for the words of wisdom and both seem like possible causes but nonetheless i still have the same problem.
    Thanks anyway.
  • Sascha Haber
    September 27, 2011 at 7:55 am
    Export and upload the project for us to investigate further , if you like.
    A slice of color…
    RAID0 8TB eSata 6TB
    GTX 470 / GT 120
    Extreme 3D+ WAVE
