Activity Forums DaVinci Resolve Power Window softness keyframable by dragging points?
  • Power Window softness keyframable by dragging points?
    Posted by Dan Powers on June 9, 2014 at 11:10 pm
    So I want to keyframe the position of inside vs outside. for example drag only the pink softness points to a new position. Often need to color scenes that need a lot of softness on the left and almost none on the right of a custom power window. What I want to do is to adjust softness gradient similar to masking in Smoke.
    Dan Powers
    P3 Media
    Austin, TX
    Marc Wielage replied 12 years, 3 months ago 5 Members · 8 Replies
  • 8 Replies
  • Margus Voll
    June 10, 2014 at 12:48 pm
    If i remember correctly this is not possible for now.
    Maybe in future releases.
    Margus
    https://iconstudios.eu
    https://vimeo.com/iconstudioseu/videos
    DaVinci 10, OSX 10.8.5
    MacPro 5.1 2×2,93 24GB
    GUI 4000 / GPU GTX 780
    DL 4K
    Eizo Color
    Scope Box
    Full Ligthspace CMS
  • Brandon Thomas
    June 10, 2014 at 2:11 pm
    Should be possible with the Power Curve. Set a dynamic for the shape and continue to keyframe from there. You don’t get a keyframe for each individual point, obviously, but you should be able to accomplish what you’re trying to do.
  • Dan Powers
    June 10, 2014 at 3:13 pm
    Cant have a hard edge on one side of a Power Curve and a soft edge on the other.
    I had to stack another node to soften up one side.
    Dan Powers
    P3 Media
    Austin, TX
  • Dan Powers
    June 10, 2014 at 5:01 pm
    Wait I found you can adjust the softness points individually , but only if zoomed to a certain level on the viewer. If the points are too close together it groups them all. CTRL + several times and you can grab the points individually. That is what I was looking for. Now if I could just pan the viewer window to see the points that are outside the zoomed region.
    Dan Powers
    P3 Media
    Austin, TX
  • Marc Wielage
    June 11, 2014 at 12:33 am
    [Dan Powers] “Now if I could just pan the viewer window to see the points that are outside the zoomed region.”
    Center click + scroll wheel will zoom out the Viewer and let you see beyond the edges of the frame. Is this what you’re talking about?
  • Rohit Gupta
    June 11, 2014 at 4:28 am
    Hold the middle mouse button to pan the image around the viewer.
  • Dan Powers
    June 11, 2014 at 4:03 pm
    Thanks for the feedback! My Kensington Expert Mouse Pro Trackball doesnt have a middle button, but I did find that pressing down on the scroll wheel and moving the trackball will reposition the zoomed in viewer.
    Loving Resolve 10! As a near life long on-line guy and someone who used DaVinci with Ursa some 20 years ago, it was an absolute pleasure to revisit DaVince.
    Dan Powers
    P3 Media
    Austin, TX
  • Marc Wielage
    June 12, 2014 at 2:36 am
    [Dan Powers] “My Kensington Expert Mouse Pro Trackball doesnt have a middle button, but I did find that pressing down on the scroll wheel and moving the trackball will reposition the zoomed in viewer.”
    I love the Expert Mouse and used it for many, many years, but I reverted to a simple 3-button Kensington wired optical mouse especially for Resolve. No muss, no fuss.
