Activity › Forums › DaVinci Resolve › Power window defocus
  • Power window defocus
    Posted by Han Kim on January 16, 2012 at 9:49 am
    i like to use defocus effect with power window
    how can i add softness everything outside window?
    thx 😉
    Laco Gaal replied 14 years, 8 months ago 3 Members · 2 Replies
  • Christopher Tay
    January 17, 2012 at 1:25 am
    You need to add an outside node to this node that you have your power window. The outside node basically takes the power window from the node before and invert it so anything you apply, ie. color adjustment, blur (defocus), sharpness…etc will affect outside the power window.
    -chrispy
  • Laco Gaal
    January 17, 2012 at 10:00 am
    even easier, and it needs only one power window, if you create a power window, set the “In-Out” switch next to the power window name to Out, and then apply the blur.
