Activity Forums Media 100 Power Point Presentation
  • Power Point Presentation
    Posted by Bob Karsner on June 30, 2008 at 5:20 pm
    I have a client that supplied me a completed Power Point presentation and wants to convert it into a video presentation and use it in a marketing DVD. Is there a good solution for this? Using the make movie function in Power Point doesn’t work.
    I am using a Media 100HDe system.
    Any info would be a great help.
    Bob Karsner
    Destiny Productions
    Bob Karsner replied 18 years, 2 months ago 2 Members · 2 Replies
  • Maxwell Federman
    July 1, 2008 at 7:10 am
    Hello
    While there are certainly other ways of exporting a movie directly from a powerpoint project, here is a simple workaround that I have found effective.
    Clients often bring me all types of media presentations that they wish to incorporate into standard-def projects for DVD output. Now that there are so many proprietary slideshow apps (including and besides powerpoint) it gets to be a time consuming hassle.
    To save time, I use a laptop to play the presentation, using the dual monitor function to allow for video output from the laptop which I feed to the capture card; creating a new video file. Most laptops only provide S-Video output of video signals, so an adapter may be needed if you do not have a multibridge.
    Of course, I would not recommend this practice for programs you intend to broadcast, but I have found that it is a great workaround to avoid frustration when working with new media in SD projects, such as DVD’s for corporate use….
    I hope this helps
    Max Federman
  • Bob Karsner
    July 1, 2008 at 6:54 pm
    Thanks for the advise. I will let you know if I come up with another option.
    Bob
