Power Mac not seeing Fibre card!
We run a Apple G5 Power PC 4X2.5GHz, 6.5GB RAM with AJA KONA LHe. I have the Display Graphics card in slot1, Kona card in slot 2, the 4GB fibre card in slot3 (800x), SATA card in slot 4. The xserver raid is hooked up and there is a violet light on from the back of the card but the G5 does not see anything. Card or drive. The drivers & fibre channel utility was installed first.Talked to my dealer tech at Promax and they said it “should” work. Maybe a bad fibre card?
