Activity Forums Maxon Cinema 4D Power button in C4D
  • Power button in C4D
    Posted by Robert Molnar on July 31, 2007 at 8:09 pm
    Hi everyone!
    I have found many many answers to questions on Creative Cow forums, but not this time.
    Can someone tell me how to make a “power button” in C4D???
    “Capsule” seems like a perfect choice to do it, but I don’t know how to curve it. I need it for a logo, and I’ll use it as letter “e”.
    Actually I need the sign on from the button and not the button itself.
    Thank you!!!
    This is what I mean: https://barack.acc.hu/
    Robie
    Robert Molnar replied 19 years, 1 month ago 3 Members · 5 Replies
  • Brian Jones
    July 31, 2007 at 11:17 pm
    I would use a bend or a wrap deformer. Just make the capsule longer and use lots of height segments.
  • Robert Molnar
    August 1, 2007 at 8:08 am
    Thanks Brian!
    Could you give me more details ’cause I’m a biginner in C4D.
    What “height segments” exactly means?
    Thanks!!!
    Robie
  • Randy Johnson
    August 1, 2007 at 8:42 am
    Are you just trying to curve the edges over? If so use your a cylander with the fillet cap option.
    Here are a few options to do this.
    https://www.randyarchy.com/rounded top.c4d.zip
    hope this helps.
    /randy
  • Brian Jones
    August 1, 2007 at 2:23 pm
    If you add a Capsule (or anything really) and it’s selected it’s properties (it’s attributes) are shown in the Attribute Manager on the lower-left of the C4D interface. There you will find the capsule has for tabs of info Basic, Coordinates, Object and Slice in the Object tab (selected by default) you will find Height Segments amongst others. It controls how many divisions the capsule has along it’s length. Play with all the settings, there’s no substitute for experimenting. Check out this example of the capsule as a Power Button. Done fast with rudimentary textures.
    https://homepage.mac.com/bdjones/.public/PowerButton.zip
  • Robert Molnar
    August 1, 2007 at 5:53 pm
    Hi Brian!
    The project you “Done fast with rudimentary textures” is
    EXACTLY what I was trying to do! It’s fantastic. I was suffering hours…
    Thank you for the project file and advices.They’ll be usefull in the future!
    -Randy…also thank you for the info……I’m saving every information about C4D ’cause sooner or later I’ll use them.
    Bye
