Activity › Forums › Adobe After Effects › Pouring water transition guidance
Posted by Brian Keith on January 26, 2011 at 1:05 amHello all…I am in need of some help. I have a video of water pouring into a tank. I would like to use it as a mask to reveal an image. Basically, I want to do a transition of the frame filling up with an image based on a video I have of water filling up a tank. Could anyone point me in the right direction on how to make this work? Thank you.
Brian Keith replied 15 years, 8 months ago 4 Members · 9 Replies -
Olin Padilla
January 26, 2011 at 1:56 amSo, if I’m following right, you shot a transparent tank filling with water, and you want the rising water/surface waves to act as a wipe, right?
Normally, a quick way to make something like this into a matte is to de-saturate it, and play with the levels until you have the areas you want isolated into either black or white. Use it as a luma matte and you’re done.
The problem I see here is that you used water. If you try to use filters to isolate it, you are going to end up with a mess of reflective and transparent sections.
Either way, the trick to this type of effect is to use filters to isolate the part of the footage you want as a matte, and to avoid manual rotoscoping.
Good luck.
Tudor “ted” jelescu
January 26, 2011 at 2:34 pmIf you have CS5 Roto Brush may help you create the matte Olin was talking about
Tudor “Ted” Jelescu
Senior VFX Artist -
Brian Keith
January 26, 2011 at 3:11 pmThank you gentleman. I see what I am now up against. I do have cs5. I will give it a try.
Walter Soyka
January 26, 2011 at 3:21 pmYou might be able to find a pre-keyed water element on a stock video site like Artbeats, iStockphoto, or Pond5.
Using the Caustics effect [link] during your transition would help make it look more watery.
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Brian Keith
January 26, 2011 at 3:46 pmAgreed Dave! I am about to fire up my Panasonic HMC 40P and do it the correct way. Thank you!
Brian Keith
January 26, 2011 at 10:12 pmTo Dave or anyone. Would anyone have any advice on how to light this? Thanks!
Brian Keith
January 26, 2011 at 10:31 pmNada. Nothing. Trying to make do with a few halogen lamps that I got at walmart.
Olin Padilla
January 26, 2011 at 11:03 pmThe main thing to remember when you are lighting it is that you are making a matte. You want as much contrast as possible, and you want to isolate the water from the background.
Assuming you are shooting with dyed water in an aquarium, I would try to do this:
Make some kind of white backdrop (a plain white wall will work fine), and get a bunch of light on it. The more even the better, but it doesn’t matter that much. Turn off your overhead likes too.
Now setup the aquarium far enough away from the backdrop that the light does not hit it. Set your camera up perpendicular to the wall and the aquarium, and play with the exposure until you have very dark water and a very bright white wall.
Make sure when you pour the water that you don’t cast any shadows on the wall or the water. And beware that if you use the wrong kind of light you will get an ugly strobing effect. It will be visible on the monitor.
Good luck.
Brian Keith
January 27, 2011 at 7:32 amThank you all so much for your help. I am almost there. BUt I am having an issue. I ended up working with the water video. I animated a black matte that followed the pour. Anyway, I am noticing that the image I am using to fill the screen with is showing where the water is pouring. I have a link to it so you can see for yourself. Not sure what I am doing wrong. I have the orange image under the matte video. The orange image is set to Luma Inverted Matte. Thanks!
https://i113.photobucket.com/albums/n219/motionman0/Screenshot2011-01-27at12258AM.png
