Activity Forums Avid Media Composer Potential workflow + problems
  • Potential workflow + problems
    Posted by Jimmy Visser on May 16, 2008 at 2:35 am
    Hi all,
    Recently I posted a problem with shifting some 24f rough cut reels to Avid. We want to go through the post process in 24fps, if possible. I decided on the following process:
    Step1, encode HDV tape, using Canon XHA1 as a deck into an .m2t file using Aspect HD.
    Step 2, Use MPEG Streamclip to export the .m2t into a Quicktime Avid DNxHD file. I converted to 1080p24 DNxHD 175 10-bit codec.
    Step 3, Import the Quicktime into Xpress Pro. Cutt in a 1080p24 project.
    A few questions, for anyone able to help:
    1) Color looks a little strange. We set the quicktime conversion to Millions of Colors+ (as opposed to just Millions), and color levels to 709 rather than RGB levels. Are these the best choices?
    2) Is that the right codec to be using? In particular, should it be 23.98 or 24fps? Half the footage in the timeline looks fine, but quite a bit looks very stuttery (which it definitely isn’t originally).
    Any other thoughts/questions/comments are massively appreciated.
    Cheers
    Jimmy
    Terence Curren replied 18 years, 4 months ago 2 Members · 5 Replies
