Activity Forums Adobe After Effects Expressions posterize time via expressions !
  • posterize time via expressions !
    Posted by Topevil on September 30, 2005 at 10:25 am
    I try to make progress bar. I made first solid and animate scale[0] from 0 to 100 in 10 seconds. Now I want that values dont go all from 0 to 100 but let say value changes only every 1 second so from smoothe animation to coarse like slow computers progress bar.
    Jacek Skro replied 13 years, 7 months ago 3 Members · 5 Replies
  • Dan Ebberts
    September 30, 2005 at 2:28 pm
    You can use an expression like this with your keyframes:
    posterizeTime(1);
    value
    Or one like this to do the whole thing (without keyframes):
    posterizeTime(1);
    linear(time,0,10,[0,100],[100,100])
    Dan
  • Topevil
    September 30, 2005 at 6:12 pm
    Yes it works fine, but what to do if I whant progres bar to move only every half second? as far i understand smalest number for posterizet time alowed is 1 !?
  • Dan Ebberts
    September 30, 2005 at 8:09 pm
    For twice a second it would be:
    posterizeTime(2);
    For once every two seconds it would be:
    posterizeTime(.5);
    Dan
  • Topevil
    October 1, 2005 at 7:33 am
    Thank you Dan ! Now I understand posterize time funcion and use of it !!!
  • Jacek Skro
    February 9, 2013 at 6:50 pm
    there is a way to “shift” posterization of time by some amount of frame(s)?
    when I use:
    posterizetime(12);
    value
    on keyframed Position property then Position change on every even frame (0, 2, 4, 6, etc.). but I want that this posterization (change of Position value) was done on every odd frame (1, 3, 5, 7 …).
    is this possible with expression?
    (btw I can’t change comps length by adding one frame to it’s begining)
