Activity Forums Adobe After Effects Posterize time on wiggle path. but not the path animation
  • Posterize time on wiggle path. but not the path animation
    Posted by Frederic Antoinette on September 4, 2019 at 4:28 am
    Hello,
    I’m trying to find a way to be able to posterize (stop motion style) on the wiggle path. but the path it self is animated. When I apply posterize time on the shape layer, well it does what it is suppose to do, and the whole layer is posterized including the path deformation.
    What i need is only the wiggle to be posterize, but the path deformation stays smooth.
    Any idea?
    Benjamin Arthur replied 6 years, 12 months ago 2 Members · 1 Reply
  • Benjamin Arthur
    September 4, 2019 at 10:37 pm
    If your animation is moving correctly without time posterization, The easiest way would be to precompose these elements, then lower the frame rate to something that approximates stop motion. If you could clarify what you’re working with, I’d have an easier time understanding – I’m not clear if you’re using a motion path combined with a wiggle, or you’re just using a wiggle.
