Activity Forums Adobe After Effects Posterize Time effect messing with path animation
  • Posterize Time effect messing with path animation
    Posted by Sami Bayley on November 10, 2021 at 8:34 am
    Hi you lovely lot!!
    I have a pretty complex scene with a lot of path animation. I always work in 24 fps and posterize afterwards to between 12-15fps to get a more hand drawn feel. However, sometimes, the posterize time effect messes with my path animations that I’ve been keyframing frame by frame. Things just aren’t in the correct place after I add the effect.
    While typing this I’ve just had a thought. Maybe its because I’m going from 24fps to 15, and after effects is creating new frames, where there wasn’t frames before? Maybe if I animated in 30fps, and then posterized to 15fps, after effects would just show frame 1, 3, 5, 7 etc? Same again with 24fps to 12.
    Is there a way to stop AE from ‘guessing’ the frames? The only way I can see, is exporting, dropping back in and then posterizing.
    Sami Bayley replied 4 years, 10 months ago 2 Members · 2 Replies
  • Walter Soyka
    November 10, 2021 at 11:17 pm
    By default, when you nest one comp in another, Ae can resample time smoothly. It is not only limited to the frames you see stepping through that nested comp one frame at a time at its native frame rate.
    However, you can override this and make comps behave exactly like rendered footage does. In a comp’s Composition Settings > Advanced window, you can check the box to “Preserve frame rate when nested.” With this box checked, Ae will only sample time from the comp on rendered frames.
  • Sami Bayley
    November 10, 2021 at 11:20 pm
    THIS!!!! Absolute gold dust mate. Exactly what I’ve been looking for. Thanks a lot!
