Activity › Forums › Adobe After Effects Expressions › Posterize Linear interpolation
  • Posterize Linear interpolation
    Posted by Tudor Baican on January 14, 2022 at 11:23 pm
    Hello friends,
    I would like to add some values to my position property.
    position + A + B
    Value A should be default linear.
    Value B should be posterize linear by a custom frame rate.
    If I use the posterize(myFrameRate) function, both values are posterized.
    Maybe somebody here have an idea to realize this behavior.
    Tudor
    Tudor Baican replied 4 years, 8 months ago 2 Members · 2 Replies
  • Andrei Popa
    January 15, 2022 at 8:14 am
    I don’t know of a posterize function, but you could use Math.floor().
    Assuming that the lineart of your B uses time as first parameter, you could define B like this:
    myFrameRate = 3;
    t = framesToTime(Math.floor(timeToFrames(time)/myFrameRate)*myFrameRate);
    B = linear(t, 5, 6, 0, 100);
    First I turn time to frames, so I can work with myFrameRate. Then I divide it by the myFrameRate value to create the steps. Then I multimplicate it by the same value to not alter the actual value of time. Then I make it time again, via framesToTime(), so I can use it in the linear function.
    If B is dependent on another value, not time, you could do something similar by using valueAtTime.
    There may be some simpler solution, but I can’t think of one.
  • Tudor Baican
    January 15, 2022 at 3:19 pm
    Hi Andrei,
    lot of thanks for your reply.
    I also came on a similar result after I post that. But I start first to turn the values in seconds.
    I think your calculation hold a frame 3 frames long. Its not really a frame rate Frames/Sec.
    I the end I think this is good and short result .
    fRate = 6;
    fps = 1/thisComp.frameDuration;
    fRateSec = framesToTime(fps/fRate, fps);
    pt = fRateSec*Math.floor(time/fRateSec);
    a = linear(pt, inPoint, outPoint, [0,0], [500,0]);
    b = linear(time, inPoint, outPoint, [0,0], [0,200]);
    position + a + b;
