Activity Forums Adobe After Effects Posterization blues
  • Posterization blues
    Posted by Hugh john Murray on April 30, 2010 at 10:18 pm
    Hallo! Working with some footage from a 7D for a project and have noticed there is posterization in shots of the sky due to colour gradation. Is there a way to smooth this out? Any ideas? Plugins, work arounds?
    Many thanks
    Roland R. kahlenberg replied 16 years, 4 months ago 3 Members · 5 Replies
  • Chris Wright
    April 30, 2010 at 10:41 pm
    first make sure that you are running 32bpc, have color management setup correctly, are using 32bpc plugins, etc.
    Next you can either use a chroma keyer or use procedural matting to isolate the blue tolerance to the blue saturation then a simple fast blur.
    I recommend Primatte keyer because it can plug holes which is useful for automatic roto work. If you don’t have it, you can use my free procedural keyer I made. Works on clouds too.
    Here’s my AE cs3 procedural keyer for luma/sat.
    use matte adj controls layer to create a procedural matte keyer using the inner/outer sliders
    https://www.megaupload.com/?d=DYVXXNIW
    https://technicolorsoftware.hostzi.com/
  • Hugh john Murray
    April 30, 2010 at 11:03 pm
    sweeeet. will try it, thanks. don’t suppose it makes a difference if there is a big plane moving through the sky or subject in foreground?
    cheers
  • Chris Wright
    April 30, 2010 at 11:18 pm
    I don’t think the plane will be a problem or the subject as long as they are not blue, but make sure you click the link I updated, not the email. Also the comp size was 720. And if the person is wearing a blue shirt, you still might have to roto. Cotten shirts tend to encompass the entire blue range/sat…evil they are.
  • Hugh john Murray
    May 1, 2010 at 4:14 am
    on second look and playing with your aep, I fear this is beyond my AE skillset. Really have no idea what to do. Was hoping for an easy plug-in – but thanks anyways!
  • Roland R. kahlenberg
    May 1, 2010 at 12:51 pm
    Try Channel Blur on only one of the RGB channels – I can’t recall which ;-). It works quite well on different conditions.
    Cheers
    RoRK
    Sell your AEPs with broadcastGEMs’ DVD series of templates. Click here for more
