Activity Forums Adobe After Effects postcard falling on table
  • postcard falling on table
    Posted by Sean Kimber on December 11, 2007 at 6:38 pm
    I’m not sure if I need to use an expression, or how I should go about doing this. I want a postcard to drop on a “table” element, but I don’t want it to fall flat. I want it to bounce a little bit after it falls, just to make the move look more natural. Any suggestions on how this can be done quickly and easily?
    Sean
    Sam Moulton replied 18 years, 8 months ago 2 Members · 1 Reply
  • Sam Moulton
    December 11, 2007 at 7:29 pm
    There’s a gravity script that’s included in the demopalette.jsx scripts. It works very well for this kind of stuff. File>Scripts>Demo Palette.jsx (i think)
    I’d try applying the gravity simulation to a null then linking your null to a 3D layer using a value + position expression. Then you could keyframe a bit of extra motion to position that may make it look better. You could also animate the orientation with just a few keyframes to add to the effect.
