Activity Forums Adobe After Effects Post-render actions in Output Module presets?
  • Post-render actions in Output Module presets?
    Posted by Eric Chard on October 12, 2007 at 3:24 pm
    Is there a way to get the Post-render actions to show up/be attached to a Output Module preset? The editor that pops up when you are creating OM presets doesn’t have a post-render action in it.
    Tnx!
    Kevin Camp replied 18 years, 10 months ago 2 Members · 3 Replies
  • Kevin Camp
    October 12, 2007 at 4:01 pm
    i believe so… set the post render actions they way you need them, the choose make template (at the bottom of the window it should have the post render actions that you set) then just set the output module settings, give it a name and that should do it.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Eric Chard
    October 12, 2007 at 4:52 pm
    Oh, I see: you can do it IF you make the OM template in the Render Queue window, using the “Make Template” selection in the dropdown list. But the “Edit/Templates/Output Module” main menu doesn’t have a “post render action” choice. Hmmm, bad design, that.
    I guess I’ll be making all my OM templates through the Render Queue window.
    Thanks dude. Are you at CH.13?
  • Kevin Camp
    October 12, 2007 at 6:39 pm
    yep, ch13, ch22/cable10 and the portland cw… all owned by the same company and all coming from the same building (well there is sales department in portland and a one-man creative staff).
    Kevin Camp
