Activity › Forums › Apple Final Cut Pro Legacy › Post-ProRes422 capture clip logging
  • Post-ProRes422 capture clip logging
    Posted by Michael Cox on December 31, 2010 at 5:09 pm
    Prior to using ProRes 422, I had been capturing using the HDV easy setup, which allows for entry of clip information, including reel number, etc, in the capture process. Unfortunately, now that I have switched to HDV to ProRes422 capture easy setup, all I can do is enter a single file name for the capture. This means that information must be entered after the files have been captured.
    My question is: can I enter the same information for several clips in a bin at one time, without having to type in the same info clip by clip? I tried selecting a group and then entering, against the first one in the Reel column, a reel number, but it did not copy that to the others in the selected group.
    Andrew Kimery replied 15 years, 9 months ago 2 Members · 1 Reply
  • Andrew Kimery
    January 1, 2011 at 1:33 am
    Enter a reel number in the Reel Column, then select a group of clips, then right click in the Reel Column and select the reel number from the pop-up menu and it will be applied to all the clips in the group. As far as I know this same process will work for any column in FCP’s Browser.
    -Andrew
    3.2GHz 8-core, FCP 6.0.4, 10.5.5
    Blackmagic Multibridge Eclipse (6.8.1)
