Post-Production Workflow – 35mm to D5 to FCP to D5
I am post-supervisor on a short being shot on 35mm. We are planning to telescine to D5, then capture the D5 to use the DVCPROHD codec and edit in Final Cut Pro. We then want to finish back on D5.
I wanted to check if this is a sane work flow or if anyone had suggestions for a better way to do it. Also, how does one go about exporting DVCPROHD to D5? Is it through use of an edl or is an upconvert possible?
Thank you very much for your help!
