Activity › Forums › Adobe After Effects › Post-keys behaviour: “keep going” keyframe
  • Post-keys behaviour: “keep going” keyframe
    Posted by Eric Chard on August 12, 2012 at 9:42 pm
    In LightWave, you can set a keyframe channel’s post-keyframe behaviour to “Linear”, in which the channel curve will continue going off in the last slope it was heading, instead of resetting or become static (curve=zero slope).
    What’s the equivalent function in After Effects?
    “Putting the HARM in ‘harmonica’ since 2005.”
    Eric Chard replied 10 years, 11 months ago 2 Members · 4 Replies
  • John Cuevas
    August 13, 2012 at 1:34 am
    loopOut(“continue”)
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • John Cuevas
    August 13, 2012 at 5:20 pm
    If it wasn’t clear, this is an expression. Set your first and last keyframe say to rotation 0 and 360, alt-click and apply the expression
    loopOut(“continue”)
    and your layer will continue along the same velocity for the duration of the comp.
    Thinkck.com
  • Eric Chard
    August 13, 2012 at 5:41 pm
    No worries, but I’m sure that’s helped some of the newer readers.
  • Eric Chard
    October 26, 2015 at 10:25 pm
    (and me, again, 3 yrs later!)
