Activity Forums Adobe After Effects Expressions Post Infinity Cycle
  • Post Infinity Cycle
    Posted by Jonathan Reyes on August 28, 2008 at 2:13 pm
    Hey all,
    I was wondering if there was an expression to continue an animation based on the keyframes previously set in a layer. For example, if I have a layer keyframed at 0 in the x axis at 0 seconds, then set another keyframe at 1 in the xaxis at 1 second, is there an expression that will continue the animation (ie move the layer to 2 in the x axis at 2 seconds, 3 at 3 seconds, 10 at 10 seconds etc). I know in Maya, there is an option called Post Infinity which maps out the rest of the animation for you. Thanks!
    Jonathan Reyes replied 18 years ago 2 Members · 2 Replies
  • Dan Ebberts
    August 28, 2008 at 2:54 pm
    This should do it:
    loopOut(“continue”)
    Dan
  • Jonathan Reyes
    August 28, 2008 at 3:38 pm
    perfecto! thanks so much!
