Activity Forums Panasonic Cameras Post advice on HPX 2000 footage
  • Post advice on HPX 2000 footage
    Posted by Dave Garcia on December 11, 2008 at 2:48 pm
    I’m posting a spot shot on an HPX 2000 in Final Cut Pro. The DP shot in 1080i 59.94 with a framerate of 24p. The footage I’m getting when I ingest has interlacing on it and I’m trying to remove it.
    I’m used to using an HPX 500 shooting at 24pa and just checking the remove advanced pulldown in the Log and Transfer window. This is not working here.
    Usually I would run a reverse telecine on this stuff to straighten it out, but when I open in cinema tools, the rev-telecine button is greyed out.
    I want to cut on a 23.98 timeline and output SD using my Kona 3 card.
    Any thoughts or help with this would be most appreciated.
    Thanks much
    David
    David Garcia
    creative director
    halflife* digital
    Albuquerque, NM
    halflifedigital.com
    Jeremy Garchow replied 17 years, 9 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    December 11, 2008 at 6:36 pm
    Use COmpressor to rev telecine your footage. It’s in the deinterlace section of the frame controls. You can work in a batch and it’s really easy. Simply drag all of your raw clips after l&t in to the compressor batch window, setup a preset and away you go.
    Jeremy
