Activity › Forums › Maxon Cinema 4D › Possible to use a bend deformer on an object….
  • Possible to use a bend deformer on an object….
    Posted by Brian Murphy on June 22, 2016 at 1:11 am
    Anyone know a way to use a bend deformer on an object that is being deformed with a spline wrap deformer? I need to have the back end of a long object being deformed along a spline, sag down at a certain point in the animation and a bend deformer would work best but it would have to track the position of the object on the spline…Any ideas?
    Brian
    Brian Jones replied 10 years, 3 months ago 2 Members · 1 Reply
  • Brian Jones
    June 22, 2016 at 2:33 am
    the deformer’s order is very important, if you have the bend as the first child of the object and the spline wrap as the second child, when you adjust the bend it should do what you want.
