Activity Forums Audio Possible to split timecode signal from recorder rather than daisy chain?
  • Possible to split timecode signal from recorder rather than daisy chain?
    Posted by Joe Bender on April 10, 2016 at 3:27 pm
    Hi all,
    I’m working on a setup where I’m planning to feed timecode from a Zoom F8 to five (5) Atomos recorders. I can save some money by using the Shoguns rather than the Shogun Studios, but they don’t have timecode loop-through. Is it possible to split the timecode signal from the Zoom F8 to feed multiple video recorders in parallel? If so, what kind of hardware would I need?
    Thanks in advance for your advice,
    Joe
    Joe Bender replied 10 years, 4 months ago 2 Members · 2 Replies
  • Eric Toline
    April 10, 2016 at 5:06 pm
    Remember that a time code signal is square wave audio not video. You can split it just as if it was a standard audio signal. From the TC out BNC connector on the F8 you can use any number of BNC splitters/adapters with no problem. You may need a TC amplifier to keep the TC signal at optimum level.
    “I push the RECORD button and hope for the best”
  • Joe Bender
    April 13, 2016 at 4:19 pm
    Thanks Eric, sounds good. Don’t think I’ll end up having this problem on my current shoot but will use this technique in the future.
