Activity Forums DaVinci Resolve Possible to select only moving pixels?
  • Possible to select only moving pixels?
    Posted by Adriano Castaldini on March 12, 2017 at 12:27 am
    Hi everyone,
    I’d like to grade separately the subject and the background. Let’s say that the background is still and the subject is moving, it should be easy to select the subject-only if there were a tool for selecting only the moving pixels (or only the still pixels). Do you know if there is something similar in Davinci Resolve?
    Thanks for your help.
    Toby Tomkins replied 9 years, 6 months ago 2 Members · 3 Replies
  • Toby Tomkins
    March 12, 2017 at 10:54 am
    The only way I can think of is to;
    Copy the clip to v2. Go to blending mode, select difference for blending mode, apply noise reduction and tweak gain, turn B&W, export that clip as something high quality like prores4444. Delete copy of clip on v2. Use that clip as an external matte to drive a correction node on v1. You will probably have to tweak the matter to get desired results, maybe with blur etc. Good luck.
  • Adriano Castaldini
    March 12, 2017 at 3:36 pm
    Wow… Smart solution! Thanks so much Mr. Tomkins
  • Toby Tomkins
    March 14, 2017 at 9:09 am
    No worries. It was an interesting question.
