Possible to save more than one file format when rendering?
Hey guys,
Are we able to render once but have C4d save different formats for each frame rendered.
For example, I always render to high quality TIF sequences but also want to render to RLAs with the depth info – I can’t get objects to blur in the background just using the Depth map from the multipass menu. I’m taking the final rendering into After Effects and use DOF quite a bit and discovered the power of RLA files with the z-depth and wish to experiment with them. Why am I rendering to TIF and RLA? I’ve never worked with RLAs and on a big project don’t want to take a chance with a not very common format so at least I have TIFs to use/fall back on.
UNLESS….someone knows how to truly blur objects using the depth matte in After effects…I can get the objects to blur but their borders are shar, I am using lens blur and use select the Depth matte layer in my sequence.
Brian
